Keyless entry code (instructions and string)
Old 05-21-2012 | 08:48 AM
Snowseeker's Avatar
Snowseeker
It was easy to find the code on the module under the dash. Lay your head by the gas peddle, look up behind the radio, see black box with at least 3 (about 20 pin) wire plugs going into it, get a mirror up in there so you can see the TOP SIDE of the black box and write down the 5 digit code you see in block letters. The code is reversed in the mirror so try it both ways. lol
  #32
Old 05-21-2012 | 08:20 PM
Skip1970's Avatar
Skip1970
our is a old piece of dinosour! 00 im told they aint got no codes under there.
  #33
Old 07-30-2012 | 04:24 PM
silverap1's Avatar
silverap1
To the people who have done this.
Do you break after every 5 digits is entered or do you just keep entering the digits till you find the right one?
Thanks in advance.
  #34
Old 07-30-2012 | 05:02 PM
Der ABT's Avatar
Der ABT
Did this to my 01, just kept plugging away till i found it got lucky and the first one was the factory reset....took about 15 min.
ive heard on some of the newer ones it locks you out after a few tries so you have to use the key once and then keep pluggin away.....
great trick though until someone tries to steal your truck this way.
  #35
Old 07-30-2012 | 05:11 PM
silverap1's Avatar
silverap1
Got it.
Thanks.
  #36
Old 07-30-2012 | 10:27 PM
robert_l_ross's Avatar
robert_l_ross
Thanks in advance.
Depends on the model year. Older models ('00-'01?) have no limit - you just plug away till you find it. Newer models will stop taking numbers at something like 30-35 digits. You have to wait one minute or cycle the ignition to start again (don't forget to go back 4 digits in the string so you don't miss a possible combination).
Read post number 3...
  #37
Old 07-30-2012 | 10:31 PM
robert_l_ross
Which is why you NEED put an alarm on your rig (or put your {Insert bad a$$ dog here} inside)...this "feature" will let a thief right in to steal your stuff.
Who am I kidding...if they want your stuff, they will get it...the alarm just gives you time to get your shotgun.
  #38
Old 07-31-2012 | 11:58 PM
precisiontile's Avatar
precisiontile
Originally Posted by robert_l_ross
Deactivating/Activating Auto-lock
1. Enter the five 5-digit code.
2. Press and hold 7/8 control.
3. Press and release 3/4 control while holding 7/8 control.
4. Release 7/8 control.
The horn will chirp once if auto-lock was deactivated or twice if auto-lock was activated.
Does this work on a 2000 Model? I have tried this but never heard the horn or had it lock/unlock.
I was lucky the day I went to the dealer and he gave my master code at no charge! I guess the smaller town dealers are a little more willing to get my business than a bigger area dealer!
  #39
Old 08-01-2012 | 12:32 AM
robert_l_ross
Post 11 I think...the 2000 doesn't have auto lock..that came in 2002 or so.
  #40
Old 08-01-2012 | 07:30 AM
Saddle-tramp's Avatar
Saddle-tramp
Is there any way to disable the key pad if I don't use it? I really don't like the idea of someone having an easy way in.
  #41
Old 08-01-2012 | 12:13 PM
Skip1970's Avatar
Skip1970
unplug the connector inside the door
  #42
Old 08-01-2012 | 12:19 PM
Saddle-tramp
Sweet. I just hoped it wouldn't mess up anything else. Thanks.
  #43
Old 09-12-2012 | 02:46 PM
rla2005's Avatar
rla2005
As usual with FTE...Awesome info in these forums! I used the info in this thread to find the master Keypad code on my new-to-me 2004 Excursion. After 20 minutes of working my way through the number list, and having to wait for the keypad to reset after xx attempts (the Key On-Key Off trick did not work for me) I tried method number 2....use a flashlight and a mirror.
Happy Dance
  #44
Old 09-18-2012 | 11:10 PM
lorrigray's Avatar
lorrigray
Cool Can I get the keyless entry code to my truck with the vin #
I have a 2007 F150 extended cab. My keys are locked inside and so is my code. Can I get the security code from my VIN #?? I really need to get in my truck.
  #45
Old 11-08-2012 | 12:29 PM
Apocalypse's Avatar
Apocalypse
You could give the string of numbers a shot...
