Good AC question
Go to this website for a pressure/temperature chart for 134a:
Pressure - Temperature Chart for HFC-134a
With a low side pressure of 45 pounds, the saturation temperature of 134a is 49.61 degrees, let's say 50 degrees. The low side pressure switch will not cutoff the compressor until the pressure gets down to 22-24psi.
Here's what you can try. Set the a/c at max ac and high fan. Connect gauges to the low and high side. Have someone hold the throttle at 1500 rpm and watch. When and if the compressor cuts out, what are the low and high pressures?
If the compressor does not shut off, increase the rpm of the engine more. As you increase the rpm, the low side pressure will continue to drop to a point. If you can get the compressor to cutout by increasing the rpm, either it cutout at 22-24psi on the low side or it cutout because the high side got too high.
Is the condensor coil clean of bugs, rocks and dirt?
Let us know what happens.
OK, I put the gages on the truck yesterday and at idle it would read 40psi and at 1200rpm's it read 30psi. I did it early in the morning so the temp was only 82 degrees out side. I forgot what the high side was but I have the notes in the truck. I didn't do any adding or anything to the system, I wanted to see what you guys thought. It sounds to me that it may be a little low on refrigerant per an earlier post. The truck has 222,000miles on it. What is this shim thing you speak of and how hard is that to check or fix. Man it sure is hot down here hehehe.
Run the truck up to 1500 to 2000 rpm when it's above 90 degrees and tell us what the pressures are on the low and high side. Does it cutout when the low pressure goes down to around 24 or less psi? If so, it is low on freon. Knowing how low it is is the challenge. You could charge it with the engine running at whatever rpm it cutout at before, with the system in normal a/c, not Max a/c! Charge until the compressor does not cutout. Leave the can upright so you are only putting gas in the system and not liquid.
If you had a digital temp probe for reading the pipe temps, you could charge it more accurately.
I do have some questions should I start a new thread I do not want to Hijack anybodys thread Thanks
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
11-23-2015 08:54 AM
