Rear sway bar install on a F350 with 20” wheels! (Pictures)
Old 12-09-2011 | 02:21 PM
Big-Sarge's Avatar
Big-Sarge
Originally Posted by jmcquarry
Big-Sarge,
Did you consider other sway bars, I noticed the Ford part has a 5/8ths diameter. I found one made by Hellwig "Hellwig Big Wig Rear Sway Bar with 1-1/2 inch diameter"
they have pics at the following website:
http://www.truckspring.com/Images/Sw...ig-wig-lrg.jpg
http://www.truckspring.com/Images/Sw...-installed.jpg
Do you see any issues with that product, price is about the same,,,probably less (no
taxes)
To be honest with you, I don't think the Hellwig had a sway-bar for our year truck out when I was ready to order. But I don't know if I would change my decision anyway. With the stock swaybar all the mounts were already in place and everything fit perfectly. Plus if I ever had a problem with anything on the rear suspension of my truck I wouldn’t have to worry about warranty issues. I am curious how smooth the Hellwig installation would go and if any has put one on yet.
  #47
Old 12-09-2011 | 02:44 PM
MNDiesel2's Avatar
MNDiesel2
If anyone needs measurements for a F 250 sway bar, I have the camper package and can measure once I get my truck back today!!! Although it's only a balmy 3 degrees out. Farenheit that is....
  #48
Old 12-09-2011 | 02:46 PM
MNDiesel2's Avatar
MNDiesel2
Is that still "good to go" weather for measuring Sarge?
  #49
Old 12-09-2011 | 03:10 PM
gsxr1300's Avatar
gsxr1300
Has anyone put one on an f250 yet?
  #50
Old 12-09-2011 | 03:11 PM
Big-Sarge's Avatar
Big-Sarge
What measurement is needed? The swaybar is 5/8 inch thick. Stock item.
  #51
Old 12-10-2011 | 12:00 PM
TheKid1's Avatar
TheKid1
I did the sway bar install on my 11 f350, with 20" wheels today. Thanks for the part numbers and pictures. I just installed the Rancho 9000XLs with remote control a few days ago.
I guess these upgrades will improve our 9500 lb travel trailer towing...
Thanks!
  #52
Old 12-11-2011 | 12:20 PM
Big-Sarge's Avatar
Big-Sarge
Thanks!
Lets us know how you like the improve handling after you tow your trailer.
  #53
Old 12-22-2011 | 08:20 PM
JOHNWSC's Avatar
JOHNWSC
Hellwig 7714 sway bar
Today I installed a Hellwig rear sway bar on my 2012 f-250 super crew 4x4 diesel.Part # 7714. I have it set on the softest setting and it made a big difference.The truck is much flatter when turning and just feels nicer driving in general.I bought it thru amazon $198.00 shipped.It cost a little more than stock.The diameter is 1 1/8" and I believe stock is 5/8".Install was straight forward with no issues.The bolt install behind the DEF tank was a snap,only the spare had to be lowered.It's a nice, clean neat install.I hope this helps someone who is on the fence as I was vs a stock sway bar.
  #54
Old 12-22-2011 | 10:26 PM
cheezit's Avatar
cheezit
always good ot see pics of people wearing there safty glasses.
  #55
Old 12-23-2011 | 10:46 AM
Big-Sarge's Avatar
Big-Sarge
Thanks for noticing the safety glasses. I wear them for every project I do in and around the house. I have about 10 different pairs scattered around so one pair is always available. It was probable all the “Brain-washing” the military did to me, about how important safety glasses are. They saved my eyesight in Iraq.
  #56
Old 12-23-2011 | 11:36 AM
jlalanas's Avatar
jlalanas
Just a couple of comments on installing this on a gasser shortbed crew cab.....
Obviously a very similar setup, only difference is the fuel tank vs. def tank. The gasser has a 35 gal fuel tank that can't be moved to get to that left side top bolt inside the frame. In addition to dropping the spare, there is also a bracket with some fittings, etc for the rear brakes that I unbolted to move out of the way. Overall a relatively easy install, however I would suggest using a shorty wrench on that top bolt (as big sarge mentioned), I think that would make it a bit easier.
  #57
Old 12-23-2011 | 06:54 PM
FTE Herman's Avatar
FTE Herman
Yes, just yesterday. I did have a little difficulyl though: We ordered a bunch of parts, several different end links and blocks hoping to come up with a combination where I could swap out the 2" blocks for the 3 1/2" ones. In the end all we added were the bar and the end links as in this configuration the bar ends sit parallel to the ground. Had we added the 3 1/2" blocks, it would have turned the bar down, below the rear diff.
It is interesting though as I wonder what I'll pick (perhaps 'hang') up on with those bar ends.
  #58
Old 01-01-2012 | 07:49 AM
TheKid1's Avatar
TheKid1
We came back from a 9 day, 2400 mile round trip towing the travel trailer. Definitely made a difference in the rear end. Basically, it moves around less.
Our travel trailer is 33' from rear bumper on the trailer to hitch, so it's a big sail...
The Rancho adjustable 9000xls were also installed prior to our trip. They also made a difference, especially with the wireless, and being to adjust them on the fly for an immediate change in ride!
Worth the time and money in my case!
Good work, SARGE
  #59
Old 01-01-2012 | 12:16 PM
Strokin'Hokie's Avatar
Strokin'Hokie
Did you think about installing an aftermarket (Thicker) bar or was that not an option?
  #60
Old 01-03-2012 | 10:22 PM
Big-Sarge's Avatar
Big-Sarge
There was only one option for the Ford rear swaybar. The Hellwig model looks alot larger in diameter...but I wanted a stock rear sway bar so Ford couldn't play any warranty games with me if i had a rear suspension issue.
