Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
My F-700 RV/jeep transport build thread
Old 08-07-2011 | 04:17 AM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Subbed. I'd like to see more.
Old 08-10-2011 | 12:17 PM
GVS's Avatar
GVS
Originally Posted by 80broncoman
Well i went and did my MPG test run and came out MUCH better than I thought I would.
I did a round trip from Mid town kroger fuel stop in Ashland Ky to Grayson Ky and back.
I did not try to drive for max MPG Ii ran 65-68on flat ground and held to floor on the hills. It only dropped 4 MPH on any of the hills.
I drove it like this to get a worse case idea of MPG.
I made sure to use the same pump and fill to same point (lower lip of filler pipe)
The result was 49.4 miles and 4.2 gallons of fuel used for 11.7 MPG.
I had heard these 12V cummins got good milage, but I didn't know it was this good. I think this is good mileage considering the over 13K empty weight, and the bluntness of the box.
I was told the higher gears would pay for themselves. It looks like they will.
Thats not just good mileage for that truck it's darn good mileage!
Old 08-10-2011 | 02:42 PM
acf6's Avatar
acf6
subscribing!
Old 08-12-2011 | 08:00 PM
80broncoman's Avatar
80broncoman
well I am leaving for Colorado a week from tomorrow. I'm gonna top of the main tank and check milage more than few times to see the MPG. I know it going to use more in the mountains.
Old 08-23-2011 | 12:48 AM
80broncoman
Well i made it here on my vacation. the truck is getting about 10-10.5 MPG during the trip from OH to CO. on flat land it will pull 65-70 mph without any problems. I pulled a 9 mile long 6% grade in 4th gear at 36mph.
I'm quite happy with that considering the 18-19K gross weight with the jeep and trailer hooked up.
From on the road, crossing the continetial divide
It looks a little out of place but it works for me.
Old 08-24-2011 | 04:52 AM
1973Ford2004's Avatar
1973Ford2004
I ventured out of the super duty forum, glad I did awesome thread great idea with the camper! Your fuel
mileage is great.
Old 09-04-2011 | 10:26 PM
80broncoman
Re-gearing paid off for sure for me. (Cruisin thouth Texas on I-40)
Old 09-05-2011 | 12:04 AM
BradyCouchman's Avatar
BradyCouchman
Not to rag on you parade but that box looks a bit off to me, any one else?
Old 09-05-2011 | 10:19 AM
80broncoman
Well that is just a little frame twist. that and of corse the cab is on rubber bushings. The rear suspension is much stiffer than the front.THe box is bolted on in the usual way except the back has 2 foot long 3/16 steel plates bolting the box and frame together. its all the usual old U-Haul parts. The 2 big brackets also bolt on the bumper and hitch.
I counted as it taken apart and it had a total of 32 1/2 inch fine thread bolts holding it all together.
Old 09-05-2011 | 12:28 PM
havi's Avatar
havi
I'll have the Roast Duck
Camper levelers, lol.
Old 09-16-2011 | 10:22 AM
mrblonde108's Avatar
mrblonde108
nice. Where did you get those frame rail splices to glove the extensions???? I need some also.
Old 09-16-2011 | 06:05 PM
80broncoman
I just measured the outer frame rail (it has a doulbe frame) and went to my local steel fab supplier. If I remember right I think they were about $130 for both.
They bent them out of .250 plate.
  #28
Old 09-16-2011 | 06:11 PM
mrblonde108
can u give me the name and number of your steel supplier.I live in Ohio close to Pittsburgh. It's called Steel Valley here but yet i can't find any local steel suppliers. This is the most backward *** area.
  #29
Old 09-16-2011 | 08:52 PM
80broncoman
J & M Steel
501 N 2nd St
Ironton, OH 45638
740-532-3032
Ask for Bob, tell him J.R. gave you his info.
thay can make anything you would need.
Send me a pm if you come down this way we could do lunch. I'd bring the RV for you to look at.
  #30
Old 10-03-2011 | 01:43 AM
broncobill67's Avatar
broncobill67
Do the stairs drag going down the highway? or do they sto in the back?LOL Nice Rig!! If you were to throw a little paint on her she will be sort of pretty. Have you thought of a two speed rear end..or a Gear Vendor overdrive?...take er easy
