Quiky: Fuse for headlight switch
Old 03-02-2011 | 03:33 AM
mOROTBREATH's Avatar
mOROTBREATH
1956 ford F-100. 223.
There is a small extra short tube fuse at the back of my headlight switch and I noticed it was blown, not sure why. But I was wondering if anyone knew what volt or amperage that fuse was supposed to be(shop manual surprisingly doesn't say...)? there is a little smudging and corrosion and I am having trouble reading it, and want to make sure I get the correct one. I think it says "30A"
Thank you very much.
Old 03-02-2011 | 05:31 AM
jaye's Avatar
jaye
I'm not sure of the amp I would have to check mine however, that fuse is only for the interior light not the headlights.
Old 03-02-2011 | 09:26 AM
ALBUQ F-1's Avatar
ALBUQ F-1
10 amps will do it, but you are likely limited by what is made in that physical size. It may be an "8".
Old 03-02-2011 | 12:05 PM
Lance Hogan's Avatar
Lance Hogan
MidFifties sales this fuse and has it listed in their book as "Special", which must mean that you can't buy it over the counter at your local parts store.
Lance
Old 03-02-2011 | 01:08 PM
mOROTBREATH
Hmmm, interesting. I found a bod of assorted short fuses at AutoZ, but I don't thing any of them are 10A.
The fuse I'm using is good, and I'm getting power at the dome light wire, but when I gook it up(with a brand new bulb) there's no light....I'm testing right at the element that touches the back of the bulb and KNOW that I'm getting juice.
Interesting. The other weird thing? All of my gauge lights still worked at the time it was blown.....
Thank you very much everyone.
Old 03-02-2011 | 06:11 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
[quote=mOROTBREATH;10040568]The fuse I'm using is good, and I'm getting power at the dome light wire, but when I gook it up(with a brand new bulb) there's no light....I'm testing right at the element that touches the back of the bulb and KNOW that I'm getting juice.
quote]
Getting juice is only half of the equation. You need a good ground as well. Check the ground for the lamp socket. A lot of times the factory puts the switch in the ground side of a circuit.
Bobby
Old 03-02-2011 | 06:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yep, Bobby's right, the door switches ground the dome light circuit. They frequently get corroded.
DieselCamper
08-18-2016 06:34 PM
kirkharrod
06-11-2015 01:32 PM
1979redf250
05-31-2014 09:58 AM
Jmatthews
01-05-2014 03:23 PM
Jermafenser
Electrical Systems/Wiring
13
01-04-2009 06:01 PM
