New 50 gallon (Steel) fuel tank by Transfer Flow (Attachment)
Old 01-24-2011 | 05:22 AM
jfritz_drfritz's Avatar
jfritz_drfritz
Originally Posted by rickatic
The only warranty issue I can see is a fuel sending unit or similar issue. It would take a crappy dealer to even cause a problem there.
As long as you don't get rust which somehow gets thru and fries your injectors
Old 01-24-2011 | 08:28 AM
rickatic's Avatar
rickatic
Mine is a poly tank from Titan
Old 01-24-2011 | 11:06 AM
Shupe Holmberg's Avatar
Shupe Holmberg
I had a Transfer Flow steel tank in my 2004 and no problems. Went with the Titan for the 2007. Just liked the idea of the plastic tank I guess. The gauge will work but not the computer. Understand that a "fix" for this is in the works. The only complaint on my 2007 is the stock 26 gallon tank. It just is no big enough.
Shupe Holmberg
moetrucker
03-18-2017 08:55 AM
gsgrape
Fifth Wheel & Gooseneck RV Towing
03-15-2016 10:40 PM
RyRoRyan
1999 to 2016 Super Duty
01-21-2016 11:35 AM
BCM
6.7L Power Stroke Diesel
01-03-2016 04:46 PM
calixt0
07-10-2015 07:13 PM
Quick Reply: New 50 gallon (Steel) fuel tank by Transfer Flow (Attachment)
