Flat load floor in 2011?
#31
Bolts are metric, 8mm x 1.25 (6).
13mm needed to remove the bin.
T-40 Torx needed to install the Folding Floor.
I was able to remove the Folding Floor from the donor truck myself, so I was able to retain the factory bolts. I was also able to get one seat mount bolt for the bottom mounting tab on the Folding Floor. I think this tab that mounts to the floor(just like the seat) could be removed, I'm sure it is stronger with it attached but it might be overkill. I put the bolt in anyway!
I have photos, now I just have to figure out how to post!
#32
You have two options.
- Be a supporting member - e.g. volunteer to pay to up your membership level.
- Post your pictures on a site like photobucket or facebook and then put links to those pics on the thread here.
#33
Thanks for the photo info. I'm not on facebook, I'll look into upgrading my membership.
To see pics of this Folding Floor now, Check out www.Du-Ha.com , look for storage for 2010 250/350. There are installation photos that show the removal of the folding floor and installation of their storage bin(nice product if you want a bin).
#34
#35
#37
So this company sells a replacement for the current bin, am I correct? The pictures show a pre-2011 truck. Love the idea of the guns storage. The current bin is not configured for it.
#38
I think they do offer a bin for the 2011. Check the part numbers, I think the difference is color. I don't think theirs locks. If you have a 05-10 it's a good way to get a bin if you want one. Even with the folding floor installed there might still be room for a rifle in a soft case. I'll take a look.
Another option would be to get a padded case/bin from a Cabelas Edition SD. I saw one on ebay. So many choices.
#39
Sen Du Ha an email
I really like the concept of this underseat bin replacement. I don't however want to lose the security of the factory lock nor the power outlet that is there. Here are a couple of pictures showing those items:
I sent them an email asking these questions. Thanks for making us aware of this option.
#40
I'll see what they say...
#41
#43
I pulled the contoured bed mat out of my '04 and dropped it in the '11. The only obvious difference I could see in the beds was the slight bulge where the fuel fill tunnel size was increased to accommodate the DEF fill tube. Didn't have to trim the mat.
I say, "If it's workin', don't mess with it".
Ford did have a pretty good idea with the lockable storage tray. Works well for some. I needed the folding tray, though.
#45
For putting you pet(s) in the back seat they make
"hammock-like" things that attach around the headrests
from and rear. We use them in our Explorer's back seat for
our Black Lab. Keeps most hair confined, and doesn't require
messing with the seats. Plus it's easy to pull-out when
people need to use the back seat.
Here is one brand (all the mail order catalogs have something similar)
Solvit Deluxe Sta-Put™ Hammock Seat Cover - Pet Seat Covers - Pet Travel Center
