'91 Cummins 12v 6BT into my 86 F250HD
#61
Sorry to jump onto this old thread, but I have a question. Can a driver side drop Dodge NP 205 from a 94 or newer cummins NV 4500 be put onto a 92 cummins getrag? I'm trying to figure out how to keep my Ford driver side drop Dana 60, while swapping donor drivetrain from a 92 dodge cummins W350.
Kinda planning a similar swap in my F150, but it's 2wd, which simplifies things a bit..... Want a 12V or 24V Cummins and 5 speed. Ought to get twice the MPG & towing power of the 300......
#62
Be careful with re-clocking the newer transfer cases. I know pretty much nothing about it, except I do know the newer transfer cases have a little oil pump inside for lubrication. So do some research and see if it would be ok and pump the oil correctly if you do decide to flip it over. The 205 might be a splash oil type box, so it might not have a problem.
As I mentioned and Rogue Wulf said, a NV4500 and newer t-case is certainly a straight forward, no hassle option. However, I know in my case having parts on hand and spending a little to make them work was still more economical than locating individual parts I didn't already have.
#63
That is good information, thanks. Yeah, if I could afford to just buy a NV 4500 and T case, I'd probably buy a new advance adapter atlas II case for the Getrag. But money is tight. Advance adapter can adapt my BorgWarner T case, and it actually has better crawl ratio and so forth. That is probably the way to go.
xringonly
380
12-04-2019 07:07 PM
AstroFab
18
02-05-2011 08:23 PM
63nova86F250
12-15-2010 04:17 PM
