Rattle noise
Old 12-02-2010 | 03:50 PM
levimorris85's Avatar
levimorris85
Rattle noise
Ok guys, the wife and I just bought a nice clean 2003 6.0L excursion 2wd. when stoped at a light, the tail pipe rattles against the fuel tank shield. Any suggestions on what to put between them, or how to stop it?
Thanks.
Old 12-02-2010 | 05:26 PM
Young Gun's Avatar
Young Gun
Is it stock exhaust? Are all the hanger bushings intact?
Old 12-02-2010 | 05:35 PM
joe joe f's Avatar
joe joe f
Make sure it is the exhaust pipe. I had a intermittant rattle at lower RPM's and it ended up being a cracked down pipe or Y pipe at the flex on my turbo. It is in the shop right now getting fixed. My friend had the same problem with his and others post that it is a common problem. With mine I also started smelling exhaust when I put the A/C on the vent option. Hope yours was cheaper than mine to fix. Have to remove turbo to get the the pipe on mine.
Old 12-02-2010 | 06:25 PM
levimorris85
Hangers are good, all 4 inch exhaust, no odd smells and when you pull the tip away from the tank it stops. Any ideas I'll check out and try.
79F250isalive!
06-25-2014 10:26 PM
calzone
1978 - 1996 Big Bronco
23
08-30-2006 11:20 AM
flagator84
2004 - 2008 F150
08-17-2004 07:05 PM
tombob
Paint & Bodywork
07-25-2003 02:22 PM
powerstroker250
1999 to 2016 Super Duty
02-24-2002 11:36 PM
Quick Reply: Rattle noise
