6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4s and Alternators.
Old 11-19-2010 | 09:44 PM
longview1's Avatar
longview1
I believe ive seen numerous posts about dead batterie/replaced alternators.
What is the deal with our trucks and eating alts???
Mine was replaced a couple weeks ago, and I got an oasis report today on my truck and saw it was done once before as well. (only have 30,000miles)
(Oasis also showed radiator was replaced, upper rad hose, and then the Venturi T installed.)
Old 11-20-2010 | 07:41 AM
senix's Avatar
senix
I have not heard of Alternators being an issue. Just the batteries.
I have an awful lot to do with the heat in the engine bay.
If your alternator goes back, get a heavy duty higher amps one and that should help.
I have the snow package on my truck, I always get that as it comes with the heavy duty alternator and the higher capacity front springs.
I still have my orginal batteries and alternator.
Old 11-20-2010 | 11:53 AM
longview1's Avatar
longview1
Batteries get a bad rap, between the extreme heat and then the extreme cold they have a tough life. I think I might get a couple battery blankets to help out.
Old 11-20-2010 | 01:34 PM
senix's Avatar
senix
passenger battery on mine has a blanket, drivers side does not.
Old 11-20-2010 | 04:01 PM
longview1's Avatar
longview1
Yup, same here. Its also that battery that is weak and wont hold a charge.
Old 11-20-2010 | 11:34 PM
ssharber's Avatar
ssharber
I ordered a battery blanket from Ford for the driver side. Yeah, I know I could have just wrapped some insulation around it, but what the heck. I replaced my batteries due to the driver side going bad with Red Tops, and the top of the driver side battery has started to raise up in a few areas like round coils, which tells me the heat IS affecting it. red Tops handle heat well, but Im still thinking the blanket is a good idea.
Old 11-21-2010 | 12:26 AM
cheezit's Avatar
cheezit
I have done far more high pressure pumps then alterntors
Tomcat71
1999 to 2016 Super Duty
06-09-2015 06:54 AM
Totally Tuna
04-02-2014 03:13 PM
emd160
06-27-2013 12:42 PM
01f350
2004 - 2008 F150
35
05-13-2008 10:50 AM
hesh8
Car/truck Buying Advice
01-18-2005 07:21 PM
