View Poll Results: Change inector O rings as a PM measure?
Yes, Change them.
19.05%
No, waste of time probably not needed
17
80.95%
Voters: 21. You may not vote on this poll
Injector o rings preventative maintenance
I was thinking of replacing my injector o rings as a pm measure. I have about 180k on my stock injectors and I don't think any work has been done on them. Would this be a good idea or a waste of time and cash? Only performance issue I have noticed was last winter upon cold start I would get a slight miss and then clear up after warming up a little. What to you guys/gals think?
I would vote no. Now, if you were changing GP's or were under VC's for some other reason and had $$ for o-rings - ya might as well 'while you're there'.
I waited until 240k on my F350 and 'upgraded' to single-shots as PM! I work out of town and just didn't want to break down 3000mi from home and be forced to pay some jackleg to wrench on my baby. A few years and a few injector changes later and now I'm not afraid to change injectors in the walmart parking lot if I had to!!! I'm gonna drive the X until I can afford big oil, Stage 3's, head studs and at least a 38R (I dream of a pro-charger...)
Grant, I was thinking of doing close to the same thing, I was thinking rebuilt or new injectors. (Im' at 240k)
Jason and I had a long conversation about this at the GTG.
He rode in my truck, listened to my engine and gave me his advice.
I have since decided against the new injectors.
Listen to Jason, he's a book of knowledge.
I voted yes but only as to where Jason was going...(not that I know anything)
Btw.... for all and not to steal a thread but my smoking issue I changed gps and o rings as well which didnt resolve issue so got some injectors from Clay at RiffRaff and life is good!!! and Wifey is happy now to sneak that sticker I got from Clay on the back of the Excursion!
With us being on the forums and seeing different failures often from time to time you can't help to think about doing some PM work before ours go Grant, you almost think our motor is one big O-RING waiting to burst. IMO you should be OK for now, I got almost 153,000 on mine and really never think about it because my truck never skips a beat(knock on wood).
Grant, I just recalled when I sheared off the injector hold down bolt in the head, and I had to pull the injector to retrieve said bolt, My injector orings looked real good for 230+k on them.
I put a new set on that one injector of course, but the old ones that I cut off were plenty pliable.
