Couple of ??
Old 11-15-2010 | 09:01 AM
69cj's Avatar
69cj
I'm not trying to make things worse but those low voltage starts could have taken the ficm out also.
Old 11-15-2010 | 09:34 AM
texans's Avatar
texans
Originally Posted by npccpartsman
I would probably suspect a bad alternator too, but the alternator may or may not keep the truck running. The BATTERIES are the electrical supply for the truck NOT the alternator. The alternator just keeps the batteries charged. You can easily overstress an alternator to the point of failure with repeated high amp loads. That's why your alternator doesn't kick on until AFTER the glowplugs kick off and why you should never use your alternator to charge dead batteries.
I agree with you there. What I was trying to get at is if the alt is good then you should be able to disconnect the batteries and the truck stay running. Yes the alt is really not made to do this. It's more for just keeping the batteries charged, and the added stress of not having the batteries in while running is bad on the alt. You should never use the alt to charge the batteries.
Old 11-15-2010 | 11:05 AM
npccpartsman's Avatar
npccpartsman
That was next on the list or were you reading my mind????? Must be a Fayettenam thing???????? Geez I hated that place
Old 11-15-2010 | 11:45 AM
69cj's Avatar
69cj
Just make sure your hotel is next to a watering hole or liquor store.
Old 11-15-2010 | 11:52 AM
dchamberlain's Avatar
dchamberlain
The "alternator doesn't start until the glow plugs turn off", is an oft-repeated myth. It's simply not true. It is slightly valid in one instance, that of dual alternators. ONE of the alternators is not turned on until the glow plug cycle is over. However, the other one is. And on a single alternator vehicle, the alternator is turned on when the key is turned on.
Old 11-15-2010 | 04:04 PM
npccpartsman
I read both documents, but I'm telling you what many tech's have told me and what I've read on my voltage meter.....MY alternator does not "produce" until my GPCM kicks out the glow plugs. Never has. I can hear the fuel pump ramp up, see the fuel pressure jump up, and hear the motor change tone when it gets full juice.
The single alt. document is a little more "ambiguous" than the dual alt. document in that it doesn't explain PCM involvement as well if at all???
Old 11-15-2010 | 04:20 PM
Misky6.0's Avatar
Misky6.0
I've noticed it takes about 45 seconds to 60 seconds for the voltage
(read via ODBII w/Scangauge2) to jump from 11.6/11.8 to 13.9/14.1 Volts after the engine starts.
Could the lower voltage be a result of increased load rather than
the alternator isn't producing power? Somewhere, I thought it
was explained the fuel pump is pulling down the voltage @ startup?
A fuel pressure gauge is my next mod.
Old 11-15-2010 | 04:26 PM
npccpartsman
If anything it's the glow plugs pulling the huge load at start up. My fuel pump only has a 20A fuse in the line and the alternator outputs a LOT more than that.
My voltage is very similar, in fact I'm going to go watch it as I start it in about 10 minutes just to see what it does.
Old 11-15-2010 | 04:38 PM
dchamberlain
The single alternator description doesn't explain the PCM involvement because there isn't any.
Personally I believe that the glow plugs draw enough current to draw down the voltage until they shut off. I've seen the same thing others have described, lower voltage until they shut off. But the descriptions and electrical diagrams are pretty clear that the alternator powers up with the key.
The single alternator wiring diagram is below. It basically says the same thing.
Old 11-15-2010 | 04:51 PM
dchamberlain
Here is a bit more information that I looked up that might help. According to the 6.0L Bible, under the Glow Plug section, each Glow Plug should draw 10-12 amps. That's 80-96 amps just for Glow Plugs.
http://dan.prxy.org/Truck/6L_bible_h.../Page_068.html
The stock alternator is 110 amps, as far as I know.
So not even considering the rest of the electrical draw on the truck, the stock alternator is near capacity just running the Glow Plugs.
Old 11-15-2010 | 06:25 PM
cheezit's Avatar
cheezit
ok so let me add to this.
the pcm does not controll the alternator. its controlled off the internal regulator.
the regulator will mot become active till the gpcm timer is off. do not mix up the gpcm timer for the gpcm light.
so far as amp draw on glowplugs that info is old and no longer part of the testing for a glowplug concern.
yes the glowplugs pull a crap load of juice. with a vat 40 I have seen 300 amp draws cranking a 6.0 over.
NEVER disconnect the batteries on a running engine to see if you have an alternator issue. the batteries act as a supressior to voltage spikes. A very easy way to kill a pcm, or any other module.
Old 11-15-2010 | 06:28 PM
npccpartsman
Page 68: Electrical Components
Several interesting tidbits in that "verse" of the bible too. I'm running a higher amp alternator than stock--it bench tests at 140 output and my voltage sits at 11.6 then jumps to 14 after a "time". I know it's glow plug related just not sure how or what dictates the alternator to "come on" when.
  #28
Old 11-15-2010 | 06:33 PM
dchamberlain
I understand that the alternator field is controlled by the voltage regulator built into the alternator.
What I don't understand is what provides the current to the "I" circuit to turn on the voltage regulator. According to the documentation, it's the HEC via the charging indicator light. According to what everyone else seems to say, it's the PCM.
  #29
Old 11-15-2010 | 06:35 PM
cheezit's Avatar
cheezit
ahhhh. ok I got ya..
it is in fact the HEC that controlls it. not the pcm.
the "I" circuit is not turned on till the gpcm timer goes off (up to 2 min depending on eot).
hope this make sence to the lot of ya
The following users liked this post:
  #30
Old 11-15-2010 | 06:40 PM
npccpartsman
My lesson for the day. Thank you very much sir!!!!!!!
Quick Reply: Couple of ??
