weird relay noise under dash
Old 12-06-2010 | 09:53 PM
chadjones99's Avatar
chadjones99
Old 12-07-2010 | 01:51 AM
IHbase's Avatar
IHbase
So... why not just unplug it and determine what stopped working- then you will know what the relay is.
-mike
Old 12-07-2010 | 06:36 AM
chadjones99
thats funny that what i told my wife i was going to do.
I guess if no one can tell me by this weekend
thanks
chad
Old 12-07-2010 | 06:40 AM
npccpartsman's Avatar
npccpartsman
I'll look this morning when I get home from taking my wife to work and see if I have the same thing in my 04 and see if I can figure out what it is. Worst case I'll get the part # and see what the parts book calls it.
Old 12-07-2010 | 12:50 PM
chadjones99
Thanks
cool thanks !!
you can see it if you take off the panel under the steering wheel ( like you were going after a fuse ) anyway take it off and lay down on floor look up toward the AC control area below radio kind of close to the floor ( its above or off floor but right behind the panel that would hold the drink cup holder area ) does that make sence ?
lloks like a relay but a lot wider
Old 12-07-2010 | 01:18 PM
npccpartsman
Originally Posted by chadjones99
cool thanks !!
Damn......I had one of those old age brain farts and forgot. I'll go do it now. At least it's above freezing and not snowing yet--LOL.
I took my radio out and looked down at what I think it is and all I can tell is that there are a lot of wires plugged in there that all go through or into the firewall. I have no idea what it is. I didn't see anything that looked like a relay but it is very difficult to see.
I did find out why my drivers side heat wasn't working correctly though.
Old 12-07-2010 | 01:47 PM
chadjones99
pics
could you get a better picture of it than what i have ?
Old 12-11-2010 | 05:07 PM
chadjones99
still need info/help
ok , more info it is now clicking sometimes when key is off and found that when it does click or chatter when key is off and door on truck is open ( should kill all power in cab , which it does but ) I can turn on my blinker and get it to flash once or twice when it is in this condtion so now i am thinking that this has something to do with the relay or switch that lets you turn off your truck and still listen to the radio , etc for ten mins before it down powers cab. so what is this item called ????
Old 12-11-2015 | 01:07 AM
Bently_Coop's Avatar
Bently_Coop
@chadjones99 Did you figure out what this came from? I may be having a similar issue?
Old 12-11-2015 | 01:23 AM
chadjones99
Yes , but that was a few years ago so not sure now. Plus I sold that truck I remember opening that box and there's a relay or two inside I just replaced them and I think the issue went away also I think I remember replacing the blinker **** off the steering wheel about the same time
Old 12-11-2015 | 01:52 AM
Bently_Coop
Thanks for the information. From what I have been seeing is the blinker relay and another. May have to get on this.
Part number to blue Relay: 5C3Z13350AA
Old 12-11-2015 | 10:26 AM
87crewdually's Avatar
87crewdually
On my 05 the relay would click at random times whether the key was on or off. What I found was inside the multi- switch (turn signal switch) broke internally and held one of the contacts closed. Replaced the switch and cured it. Got the switch the cheapest @ Advance Auto using promo code trt30.
See below. I'm pointing to the broken piece with a screwdriver.
In this pic I'm pointing to where the piece came from.
  #28
Old 12-12-2015 | 05:20 AM
Bently_Coop
Thanks, I am picking up a relay tomorrow and will find out if that changes anything. Multifunction switch looks to be about $120 +tax from Horizonpartsguy.com. I have only heard the clicking while key off Engine off, key out of ignition, once key is on clicking goes away.
  #29
Old 12-12-2015 | 07:25 AM
87crewdually
IIRC EP27L from Napa is what I use. It plays well with LED lighting if you ever swap out.
NAPA LED FLASHER
  #30
Old 12-12-2015 | 07:11 PM
Bently_Coop
Installed relay from Ford. Definitely go through the radio hole. If you have a long skinny arm you could get through the ash tray slot or trash hook but the cover is a little stiff back there.
