Mercon SP or Mercon LV
5R110W. Even if I asked what fluid they used, I'm not sure I could believe it, so I am assuming the wrong stuff. Went to the local Ford place and asked them if they could flush, they said no because it is a motorhome. I bought them out of fluid and a filter (line). I will change pan juice and in-line filter, run a while, and change again. I would prefer a Ford flush instead but......
Here's DIY tranny flush procedures by Mark Kovalsky:
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
It's for different transmissions, but I believe it'd work for yours too. Maybe somebody can confirm???
Good luck!
Good luck!
New is better. Even my Powerstroke was design to run on dino oils, I use synthetics on it.
So going for newer stuff would be logic conclusion.
Than occasionally manufacturers do "OOPS" on new stuff....
Good luck with your decision.
Per my experience oil quality plays little role in the machinery life. Even if you fill it up with cooking oil, it will run for pretty long time. Not that I would try...
Can you be more specific. What aftermarket stuff have you used? Any of that stuff full synthetic? Also on which tranny? For how long? How many miles?
Sure UA VAJ
lol
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and
Valvoline.com > Products > MaxLife > Automatic Transmission Fluid MaxLife > MaxLife® DEX/MERC ATF
lol
