quick question re compression test
Me once again!! Finally got my compression tester and adapter. Before I tear into anything, was wondering if I need to remove the oil drains and fuel drain before removing my glow plugs...Last thing I need is to hydrolock this blasted Excursion! I know to do it for injector removal (already done that twice now!), just curious about when removing only the gp's
Thanks, I have a handy magnet makes quick use of getting them out... I feel better now that all cylinders are 420 to 400...at least now I have gotten rid of one reason for smoking so bad....injectors otw! What size tubing is that your using?
Yea I feel better about the whole thing... Bought this truck with 108k..at 120 got a cracked injector cup and its been down hill since... Upon noticing this thing has a rebuilt HPOP installed, now after new head gaskets and cups now this!!! I just had to do the test myself to take away any doubt about possibly losing a cylinder. Still havent solved my smoking issue...
Don't know the size of the tubing. It was just laying around.
I tried to do the cups myself and screwed it up...took to a mom and pop shop and they pulled the heads and had them tested and cups were put in at ford shop...anything else i may be missing for this smoking issue at startup? I replaced the IPR; new gp module; gps are new last april and they ohmed out good all at .5. Pulled injectors and 2 had the ends charred looking...no codes but they looked like crap...anyway figured I would get at least that side of the engine swapped with injectors from Clay....guess I havent changed the oil and thats next as well as new fuel filter...anything else I could look at while engine apart?
