low fuel pressure displayed
Glad to hear the low pressure pump was covered in both instances you referred to
I assume from some gelling. A few years ago they mixed the winter blend like chit. It was when the bio-blend diesel came out big in central IL. I went through 3 fuel filters and a few bottles of Power Service 911. It was irritating but the Cummins 5.9 fuel filters were cheap and easy to change out.
OK, I did not drive her the past 2 days. I started her up a few ago (39 degrees) and the son and I headed to Starbucks. Just before I hit the on-ramp, I got the "Low Fuel Pressure" warning again.
As I accelerated normally, she was fine was fine. I got onto the highway and reached 69 MPH. I then pressed the accelerator pedal further (about 1/2 the way down) and had hesitation. She would not accelerate faster. I did not get any further messages or a limp mode etc. I continued driving to and from Starbucks without issue unless I attempted to accelerate hard, then I just got the hesitation but no further messages. She is parked outside now and I go into surgery tomorrow for the rotator cuff and labrum repair (left shoulder).
Could it be as simple as a slightly gelled fuel filter with a block? This never happened last winter and no issues until we had single digit temps this year. Fuel filter was last changed at 10-11K miles (I change it every 10K) and was done by the dealer.
I didn't have any issue with this last winter, even in double digit negatives. I believe it is either a crappy mix of te Bio-Diesel blend fuel that is standard around here or the pump itself (but no codes so I think it is the fuel). I only use Mobil or Shell as well. It's all bio blend around here.
#29
#30
