1978 - 1996 Big Bronco
Coolant leaks in very cold weather?
Old 02-24-2003 | 12:07 PM
JBronco's Avatar
JBronco
It seems like every time the temp drops down to 0 or below, I get a nice green puddle under the truck in the morning, even if I did not drive it the day before.
Everything that holds coolant in this truck is new. All hoses, the radiator, the heater core, the t-stat, the water pump, the intake manifold gasket, the coolant recovery tank, and one freeze plug as well. The truck is filled with a clean antifreeze / water mix.
Today it seemed to be coming from where the radiator lower hose attaches to the water pump. We tightened all of the hose clamps. Hopefully that is all it is. Why do I have so much trouble keeping coolant in this truck? It has always been a battle. I don't think it has anything to do with pressure, the truck hadn't been driven for two days and was not leaking when I parked it.
Old 02-24-2003 | 12:10 PM
Squiggy's Avatar
Squiggy
Maybe you dont have a strong enough mix and its freezing just a bit and expanding the hose clamp allowing it to break open, I would check that first
Old 02-24-2003 | 12:42 PM
JBronco's Avatar
JBronco
It was just checked with the meter and the mix was good.
Old 02-24-2003 | 03:24 PM
AlM's Avatar
AlM
yo J,
It's not from the plastic side pieces?
Look here if you didn't exclude the side panels:
https://www.ford-trucks.com/forums/s...threadid=98563
Old 02-24-2003 | 03:37 PM
JBronco's Avatar
JBronco
The radiator is new. Anyway it was leaking at the top of the lower hose where it joins the water pump. I don't know why I am constantly having to fiddle with coolant leaks though.
Old 03-02-2003 | 05:51 PM
AlM's Avatar
AlM
yo,
Just found this Hose Clamp TSB for 95-96:
http://www.diesel-central.com/Tech/f...cs/95-6-16.doc
wakeupluis
01-01-2017 07:01 AM
ElMoco
46
11-28-2016 10:42 PM
GormGorm
13
12-25-2014 12:28 AM
mozzles
08-23-2014 11:06 PM
88grandmarquis
11-03-2009 08:09 PM
