Some ZF questions
Some ZF questions
Before I start looking for a ZF to replace my mada m5r2 slush box i have some questions on some differences. First off, do all ZF's have external slaves, if not, which year would i be able to find it on. Also, do any ZF's have a VSS or is this only limited to the 2wd version? I swapped a 9" in my 93 F150 and now i have no where to get my vehicle speed, if the ZF has it, that would be choice. Thanks.
Awesome news about the slave. About the speedometer, i have the BW1356 that i'm going to continue using when i put the ZF in. I know that there is no speedsensor on the tcase, so i'm still stuck on what to do with that. I found this slipyoke eliminator that i'm seriously considering on buying and i could use that as part of my VSS. If I were to devide 108 (i'm pretty sure this is the number of teeth on the ring in the 8.8) by 4.56, my gear ratio that would tell me how many of teeth I would need on a ring if I were to run the vss off the driveshaft. I could either get that may teeth cut out of the slipyoke elim. or get a ring with that many teeth cut from it and have it pressed on to the slipyoke elim. Any ideas? Anyone confused?
i'll give them a call and see how they set is up for the 9", i'd rather not have it on the axle as it will be closer to the ground and near things that could damage it. I'd kill 2 birds with 1 stone with the slip yoke elim. setup, just have to figure out how to get teeth cut into it or a ring, like the one they have on the 2.5 ton rockwell in the pics and press it onto the slip yoke elim.
'97f350supercab
12-04-2016 08:06 AM
Poorboy1967
09-07-2016 04:53 PM
mountain dewd
08-23-2016 03:50 AM
