Recirculate in other modes?
power,
I saw a thread - somewhere - where there is a mod to add a button to control the main vent that goes to the outside air. The button would allow recirc on any of the vent settings. I read the mod. Seemed pretty easy to do.
I'll have to see if I can dig it up.
Perhaps someone else can help locate it. It exists.
CMOS
CMOS
The vacuum plug connector (behind dash) that leads to the HVAC controls has several vacuum lines in it.
The white vacuum line controls the re-circulation door (closed at full vacuum).
The yellow vacuum line controls the floor/panel door.
I'm thinking that the mod somehow ties the white vacuum line in with the yellow line. Maybe a "T" off the white line into the yellow line, something like that.
You sure it wasn't to trigger the a/c compressor in all modes?? I recall that one, but haven't seen a recirculate in all modes mod... Is the recirculate door somehow tied into the coolant redirect valve?? I want to be able to do recirculate in panel and floor because of the ability to change the temperature a/c or hot, have the moisture removal of a/c and not have to cool outside air... I will look to see if i can find a vacuum diagram... I have a feeling the yellow line is a PV line, and not full vacuum... If you find any leads let me know!!
After thinking about it, the problem I see with modding the recirculation door control by way of vacuum is that, it appears that the same white line that feeds vacuum to the re-circ door is also the same source of vacuum (gray vacuum line) for the hot water control valve. At least that's my best guess as to what the gray line and associated vacuum control motor represent in the first diagram above.
In short, it appears that the re-circ door and the hot water control valve are on the same vacuum circuit. It makes sense because, in stock form, the heater control valve only gets closed when the MAX A/C mode is selected.
You wouldn't want to cut off warm coolant to the heater core in the middle of winter, which is what happens when the heater control door closes by virtue of vacuum.
In my area on any day it smells rather nasty and I figured the recirculate on floor/panel would be beneficial. Just wondering if anyone had done it before with success because the smell is unusually annoying.... Just have to figure out a way around the heater valve shut off... Don't really want to drive around when it snows with Max A/C on... Maybe some sort of button that is hooked to a valve that opens or closes it when it gets a signal, so to signal the recirc door to open or close... Just don't know what kind of valve... My F-350 allows for heat and cool on MAX a/c but since the heater core has hot coolant in it all the time it makes for pretty warm a/c on 100+* days unfortunately...
