F4 spare tire carrier available
Old 07-31-2015 | 09:49 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
It occurred to me that some of you may have figured out that I won't be using the spare tire carrier that mounts under the F4 now that I have this shorter bed. The tire would be sticking out the back.
So if anyone is interested, pm me. Stu said he doesn't need it any more.
I do not have the correct hanger bolts, as I believe they are made of unobtainium.
Old 08-01-2015 | 12:17 AM
jmadsen's Avatar
jmadsen
How far does the tire stick out? Maybe if you fab up a bumper if sorts that is farther back from the edge of the bed it will cover it?
Maybe
Your truck is looking good.
Old 08-01-2015 | 01:08 AM
Jolly Roger Joe
Maybe
Thanks Josh.
Well, it won't work. The bed is aligned with the back of the frame.
Here's a shot I took of the "bulge" factor when I had the first short bed I was going to use. I scrapped that idea because I couldn't use the tire carrier.
The spare tire would stick out 6" beyond the back of the frame. I guess I could mount it and see how it looks...
Old 08-01-2015 | 03:20 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Joe - you'll recall my prior erroneous ***-u-me-ption that a spare would mount under an F-4 same as under mine. Your picture showing the rearward axle mounting location, and related use of the extra spare support brackets, makes it obvious. Both reading it and seeing it helps old people sometimes. Thx. Stu
Old 08-01-2015 | 03:34 PM
Jolly Roger Joe
No problem Stu. I don't really NEED to get rid of the spare carrier. I just started this thread in case someone needed it, since I won't be using it now.
Old 08-06-2015 | 02:53 PM
Jolly Roger Joe
Hoarding begins?
OK, I changed my mind. I'm going to hang onto this spare tire carrier.
Since they're so hard to find, I might want it someday.
Is this the beginning of a hoarding problem?
Old 08-06-2015 | 03:32 PM
truckdog62563
Do you have the large size storage locker yet, or 40' x 60' metal building? If not you're probably safe - for now. Stu
Old 08-06-2015 | 03:51 PM
Jolly Roger Joe
See, that's exactly the problem. We're looking for a place with at least a 40' x 40' shop. Or a place to build one.
I like the way you think about the 40' x 60' though. More room to, er, ah, work... yeah, that's it.
Old 08-06-2015 | 04:23 PM
truckdog62563
Whichever you do, it won't be big enough. Stu
Bondora68
01-05-2019 04:49 PM
Superblue400
05-04-2018 01:18 AM
pezsox
04-23-2018 10:06 PM
Bob at warsaw
15
08-08-2012 09:53 AM
Matt '64
10-04-2010 10:40 PM
