77 f350 460 California Vacuum Line Diagram
Good afternoon guys i have looked allover and have not found anything definitive to my answer I have a 77 f350 w/460 c6 2wd I need to smog. I am need of a vacuum diagram for. Specs as follows:
1977 F350 California
460 c6 trans
non catalyst
It has a vaccum port on the front of the carb plugged.
It also has a looped vacuum line coming from the front vacuum tree going to a T not to far away down the line.
Any help would be much appreciated as any one knows if there is a line out of the place the smog **** will not smog my beast.
460 c6 trans
non catalyst
Originally the engine would have had a calibration sticker, usually on the driver side valve cover. There would be a "calibration code" on the sticker that is needed to get the correct vacuum line diagram for your rig.
If you still have that sticker / code it will help get to the correct diagram
I went through this many years back with my '78 F-250. As I remember there were several different configurations. Where the truck was sold (California or 49 state), altitude, GVW, etc. all come into play.
Good luck.
Good luck.
The following users liked this post:
There was a fella on this forum a few years back that had the book and diagrams that would share the info .. I copied as much as I could to my server .. I don't know where he has got off to because he was the go to guy for emissions back then .. That printed material seems so hard to locate these days and then getting someone to take a high resolution pic is the problem ..
Good luck.
Good luck.
FrankGRUN
16
06-07-2022 05:20 AM
jab55
07-21-2016 10:27 PM
Crewcabber
07-25-2015 09:00 PM
Crewcabber
07-25-2015 04:14 PM
Mestrell
01-08-2013 10:13 PM
