Beautiful Mustang also. Looked at the article, could you brag just a little and post pics of the rest of your stable besides your Comet
Here is the 86 GT drag car. The quickest I ran was 9.42 with a 428 ci small block Ford. I traded this car less engine and transmission and some cash for my second Cammer.
Here's my 05 Saleen. I've sold the 65 Fastback, 67 Coupe and 71 Mach 1. I also sold the 62 Country Sedan, it was originally bought to put the Cammer in.
I was driving without my hood for a while and it definitely made a difference with the alingment. Put your hood on first.
The hoods not ready. I'm taking it to Moab this weekend without it so we got the alignment close. We'll get it right after the hood is on and everything has had a chance to settle.
Just got back from getting the alignment done, drives like a go kart but the brakes are way too much. I need to figure out how to soften them up with this hydro boost.
Really? Personally my motto is the firmer the better.
They lock up with the slightest touch. If you just touch the pedal the truck will stop, you have to pull it up to release them.
Try adjusting the rod shorter that comes out of the hydroboost and pushed the bore of the M/C. As far as I understand a little goes a long way. I don't remember which pump you used. Maybe get a different Pressure Relief Valve for it so it will kick out less pressure.
