Needle bearings in the tranny pan
Old 05-02-2013 | 08:54 PM
brwolfjr's Avatar
brwolfjr
Got em two years ago. They still look new.
  #47
Old 05-02-2013 | 09:08 PM
Bonanza35's Avatar
Bonanza35
Tousley Ford, there a sponsor and cheap enough, OME parts.
  #48
Old 05-03-2013 | 08:57 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Originally Posted by brwolfjr
It had a broken bearing race. I have no idea what that is.
The bearing race is the sheet metal part that holds the needle bearings in place. If the race breaks the needle bearings fall out and end up in the pan.
  #49
Old 05-03-2013 | 05:38 PM
brwolfjr's Avatar
brwolfjr
Mark, thanks for chiming in. Is this a rare failure. I don't ever recall anyone else have that problem.
  #50
Old 05-03-2013 | 06:23 PM
Snowseeker's Avatar
Snowseeker
I don't want to argue with the trans guru, and maybe bearing part terminology is different in transmissions. But from all the bearings I have worked on the bearing race is the inner and outer part that the rollers or ***** ride on, the sheet metal part that holds the roller or ***** spaced out and in their spots is called a "cage" or "bearing cage".
  #51
Old 05-03-2013 | 06:53 PM
mueckster's Avatar
mueckster
The thrust beariings contain needles that are housed between two metal interlocking plates. They are referred to as Torrington bearings.
  #52
Old 05-03-2013 | 10:33 PM
Mark Kovalsky
Yep, you're right, I was distracted while I was typing. I was describing the cage, not the race.
  #53
Old 06-27-2013 | 07:15 PM
rtalich's Avatar
rtalich
Just checking to see how things are going? Did the tranny situation get resolved?
  #54
Old 06-28-2013 | 07:11 AM
brwolfjr's Avatar
brwolfjr
I got the truck back last week.
The local shop was great, but took way too long in my opinion.
Truck is running well in most of the settings, but I think the throttle is a little too sensitive on the higher hp settings.
Craig Catron
08-15-2018 11:04 AM
timbersteel
08-13-2010 12:08 PM
pk8950
03-28-2008 06:19 PM
2kcrewcab
1997-2006 Expedition & Navigator
03-09-2008 11:04 AM
ojosdestranger
1978 - 1996 Big Bronco
11-19-2004 05:10 PM
Quick Reply: Needle bearings in the tranny pan
