HIO Silver's Lo-Buck Bumpside Build
#692
#695
#697
That's a nice welder.
I'm anxious to hear what you think of the round Magnaflows. I've been considering them when my oval turbo mufflers rust out. The round seems like they'd package better under the bed. I have the stock auxiliary gas tank and my pipes are routed similar to yours.
I've never TIG welded so this is a totally new world. We'll see how it goes. My goal is to eventually fab up a stainless steel fuel tank.
Only manly grunts are allowed in FTE!
#698
#699
Man, I just spent the entire day reading this thread. AWSOME. I laughed, I cried and sometimes I even threw up in my mouth a little. BTW, The wedding was post number 202. I am amazed at how much you all know. I consider myself a decent shade tree mechanic but I actually feel a little less confident in my own abilities now after being completely lost in some of these posts and terminologies. I have thoroughly enjoyed this thread and can't wait till the LBB is flying down the road!!
Thanks Hio for all the great entertainment!
#700
Alright, just finished the entire thread as well… wow, lots happening on this build. I have to say you are providing a good mix of JY finds, refurb of the original stuff and some new items thrown in for our amazement. Also love how you get those payments from the rentals and get the next item for the shop. Please post a Youtube video soon of the engine running and let us hear it start, some throttle punches and idle as well. Details on the trans and the EFI unit will be great. I'm sticking with my '67's original FE 352 engine and may go with the edelbrock manifold and a carb in the 650 cfm range. I too am looking to get a decent bit of gas milage at highway cruise if possible. Keep it up and remember the days are only getting longer!
#701
"The Wedding" dawned on me while prepping to get on with reaching a milestone. It seemed to me appropriate at the time with the Old Man FE getting hitched to his young modern bride.
![Big Grin](images/smilies/biggrin.gif)
The Diversion 180 is the result of six months of "work". Sometimes it's easy and, as you have read, managing the rentals sometimes catches up with me.
______________
'Got a late start today with the exhaust.. the Magnaflows are mounted directly underneath the cab with the back of the case even with the carrrier bearing. One tube will exit in front of each rear tire. I was planning to routing it out the back but it is really crowded back there considering the axle flip, the future rear-mounted Scout tank, and the tow hitch. Each side will be removable due to the crossmember modification - the head tube, the muffler center section, and the rear which turns 90°, makes a quick 45° turn, then about a 15-inch section of exit tubing. I'm using stainless lap band clamps to join the sections... each section is fully welded.
I ran out of daylight working on the rear section on the passenger side . It slipped my mind that each side has to be fabricated on its own due to the 2-inch offset of the driveline. Meaning one side is not mirror reflection of the other. DOH!.. found out the hard way but luckily a lil geometry and cutting has it exiting in the correction location... packed up the gear and came inside where it is warm. Hooey it was chilly out there (for California!).
Gotta put in a day at the office tomorrow but I'll be back at it on Saturday. 'Might even have some time to install the front swaybar.
.. I'm already planning my next project: Project Prerunner: "Big Red Dick"
#702
Progress is progress no matter how much or how little. It's a good feeling to see something you're working on begin to take shape in front of you and know that you are ever closer to it running under its own power and being back on the road again.
![Okay!](images/smilies2/thumb.gif)
You and I have the same style front sway bar (mine came from a '78 F-250 CS). I couldn't find one locally but bought one off a guy over at Fordification, in the Wanted section there. That was nearly two years ago.
In the span of time since I got the front bar, I've been looking for a factory rear sway bar from a Dentside F-100/150 or a '78/'79 Bronco (a factory sway bar designed for a 9-inch rear end). I wasn't able to locate one around my area and I have also done a LOT of online searching for one, off and on. But, finally last Friday, I located a rear sway bar assembly from a '79 Bronco! Yeah!
Now, I'm fully aware the '73-'79 F-100s and '75-'79 F-150s, '78/'79 Broncos have a 4" wider frame spread from the back of the cab out to the trailing end of the frame, than my '69 F-100. However, split that dimension in half and we're only talking a difference of two inches per side.
I think I can fabricate a couple of spacers or, make some offset end links to bridge the gap to make the rear sway bar bolt up and work.
Notice the curve in the center that fits around the 'hump' on the back of a 9-inch rear end housing.
![Smilie](images/smilies/happy0161.gif)
![](http://i1093.photobucket.com/albums/i424/ultrastang68/Mobile%20Uploads/_1_zpse1345697.jpeg)
#703
Roger that! Moving forward is a great thing.
I picked a rear 3/4-inch AddCo swaybar in the JY a couple of years ago. I was on it like a buzzard on carrion! It was going to be okay with a shackle flip but now that the LBB has an axle flip, the bar interfered with the repositioned shocks. It appears it will be okay turned around 180° with its arms pointing rearwards. I've got the tow hitch c-clamped in position and it'll clear although a rear-mounted 22-gallon Mustang tank would be an iffy proposition.
The Bronco rear sway bar will probably work out with a couple of offset frame-mounted brackets... heavily gusseted of course. Dentside Broncos in my neck of the woods has become very rare... in fact, I haven't encountered one in over three years at the JYs I frequent.
I've got an extra front sway bar if anybody is looking.
#704
Exhausting!
A late start today due to domestic duties and errands....
Tacked up the right tail section, welded in some hanger brackets, and pulled the system for finish welding, and painting of the welds. Some boogered, some well done. Oh well... at least they are mine.
Tomorrow is exhaust wrap, installation of the system, and likely a driveshaft... the one that has been sitting on my coffee table for a couple of months already.
.... and mounting the front swaybar.
![](http://i62.tinypic.com/j8fmgm.jpg)
EDIT: 100,000+ views? I am amazed.
