Ford Tech Sheds Light on Gen 1 Coyote ‘Soft Valve’ Issues
By -
Ford Tech Sheds Light on Gen I Coyote Valve Issues
The Coyote is a great engine, but nobody’s perfect. Here’s the straight skinny on a common issue for early Coyotes.
While we may love the Ford Coyote V8, each generation of this engine has had some sort of issue. These issues typically pop up at higher mileage and are usually repairable. Today, we’re focusing on the 2011 to early 2014 Gen 1 Coyote with some help from one of our favorite YouTubers.
In a world of style-over-substance content, YouTuber FordTechMakuloco is the antidote for clickbait. He’s always got the best advice for late-model Ford owners like us.
In this video, he’s tearing down a Coyote from a 2013 Ford F-150 that had a slight misfire at idle. On the surface, this may seem like a fairly benign issue. You might think you can fix it with fresh plugs or ignition coils. Unfortunately, it’s not that simple.
On these early Coyotes, the intake valves are too soft, and will actually sink down into the head, with the valve seats flaring the valves out like the petals of a tulip. The resulting loss of compression will cause a slight misfire.
A Fresh Start
Ford did fix the issue on subsequent models, and there is an updated valve available for these early engines. However, to install them, you’ll need to tear the whole top end apart. Even if you pull the engine and do all of the work yourself, you’ll still have to send both heads off to the machine shop.
This is why FordTechMakuloco suggests buying a Ford remanufactured engine and swapping it in instead. These engines have all of the latest revisions for new parts, and you’re effectively getting a brand new engine with zero miles on it. That beats dumping money into a shortblock that’s still got over 100,000 miles on it.
Even though the engine won’t be saved, FordTechMakuloco still disassembles a head to show us in detail how the issue manifests. Looking at each combustion chamber, you can see the valves sitting slightly proud of the “bridge” between them.
On cylinder number four, though, the intake valve is recessed. That’s the cylinder that failed the leakdown test. When he removes the valve, there’s a prominent ridge formed by the valve seat. The valve seats themselves are mostly okay, but they are worn as well.
The valve itself is completely ruined. The edge formed by the valve seat is actually sharp enough to cut a shop towel. It should be smooth, consistent, and slightly beveled instead.
Armed with this knowledge, you can shop a bit smarter if you’re looking to buy a 2011-2014 Ford F-150. If you own one of these trucks, you’ll be better prepared to deal with the issue if – and when – this problem pops up.
Photos: FordTechMakulco via Facebook
Join the Ford Truck Enthusiasts forums now!
Cam VanDerHorst has been a contributor to Internet Brands' Auto Group sites for over three years, with his byline appearing on Ford Truck Enthusiasts, Corvette Forum, JK Forum, and Harley-Davidson Forums, among others. In that time, he's also contributed to Autoweek, The Drive, and Scale Auto Magazine.
He bought his first car at age 14 -- a 1978 Ford Mustang II -- and since then he’s amassed an impressive and diverse collection of cars, trucks, and motorcycles, including a 1996 Ford Mustang SVT Mystic Cobra (#683) and a classic air-cooled Porsche 911.
In addition to writing about cars and wrenching on them in his spare time, he enjoys playing music (drums and ukulele), building model cars, and tending to his chickens.
You can follow Cam, his cars, his bikes, and his chickens at @camvanderhorst on Instagram.
How to Guides
View All >
4 Ford Trucks That Have Gained Significant Value Recently
Slideshow: These models aren't exactly what comes to mind when one thinks of collectible trucks.
Read It
Top 10 Fords from a Secret Museum You’ve Never Heard Of
Slideshow: Ten of the best Fords on display at a museum you never heard of.
Read It
This Wild Ford Maverick Was Built to Carve Corners
Slideshow: It's good at more than just hauling stuff.
Read It
Refreshed Ford F-150 Raptor vs All-New Ram 1500 RHO: Comparison
Slideshow: The off-road pickup battle has changed a bit.
Read It
